  • RG-S2915-L Series
Service port
24 x 10/100/1000BASE-T Ethernet ports with auto-negotiation, 4 x 2.5G/1G SFP ports
68 Gbps
Capacity of MAC address table
2 x fan module
Input power
Rated input voltage range: 100V AC to 240V AC, 50/60Hz
Max. input voltage range:90V AC to 264V AC, 50/60Hz
10 kV
Management port
Forwarding rate
Cooling mode
Fan cooling
Power consumption
403W (PoE budget: 370W)
440 mm × 292 mm × 43.6 mm (17.32 in. x 11.50 in. × 1.72 in.)
Warranty
3 years
Killer Layer 2+ Access Switch
Applications
Switching capacity:
68 Gbps
Forwarding rate:
and Uninterrupted Connection
Are there any recommended RG-S2915-L series switches provide PoE power supply?
The RG-S2915-10GT2MS-P-L and RG-S2915-24GT4MS-P-L are recommended. They provide up to 30 W power per port to meet power supply needs of terminals such as VoIP phones, IP cameras, and access points (APs).
236
Because our equipment room is near meetings rooms, we are concerned about noises caused by switches. Can we use the RG-S2915-24GT4MS-L switch in such a scenario?
Yes. The RG-S2915-24GT4MS-L switch adopts a fanless design and dissipates heat in a natural manner without noise. Even if your office is near the equipment room, you are free of worries about noises. The switch also supports energy efficient Ethernet (EEE). Idle ports shut down automatically to save power.
230
Are 2.5G fiber ports of the switch backward-compatible?
Yes. The 2.5G fiber ports of the switch are compatible with SFP transceiver modules and backward-compatible with 1000 Mbps.
235
Documentos
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
Fixed Service Ports
24 ×
4 × 2.5G/1GE SFP ports
2 × 2.5GE/1GE SFP ports
Power modules
1 fixed power module
Fans modules
2 fixed fans
2 fixed fans
1 fixed fans
System Switching capacity
116Gbps
68Gbps
68Gbps
30Gbps
MAC Table Capacity
SDRAM: 512 MB
Flash Memory: 64 MB
< 30 W
< 15.6 W
< 33 W (non-PoE)
< 403 W (PoE full load)
< 16 W (non-PoE)
< 141 W (PoE full load)
≤ 37 dB
≤ 39 dB
≤ 37 dB
Power port: 6 kV/2 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
IEEE 802.1Q (4,094 VLANs)
Port based VLAN
SSHv1, SSHv2
IGMP V1,V2 snooping
Temperature Monitoring
Temperature Alarm
Overtemperature Protection
TFTP client
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
TOP
