RG-CS88-08 Switches - 1
RG-CS88-08 Switches - 2
RG-CS88-08 Switches - 3
RG-CS88-08 Switches - 4
RG-CS88-08 Switches - 5
RG-CS88-08 Switches - 6
RG-CS88-08 Switches - 7
RG-CS88-08 Switches - 8
RG-CS88-08 Switches - 9
RG-CS88-08 Switches - 10
Key Specifications View More
Dual-Boot Backup
1+1 Supervisor
Module Redundancy
1+1 Supervisor
Module Redundancy
N+M Power Supply Redundancy
1+1 Fan Redundancy
1+1 Fan Redundancy
RG-CS88-08
2 x supervisor module slots
6 x line card slots
4 x power module slots
Supervisor module
CM88-CM
Switch fabric module
Line card
CM88-48GT-H
CM88-48SFP-H
CM88-48XS-H
CM88-8СQ-H
RG-PA600I-F
RG-PA1600I-F
M08-FAN (pre-installed 2)
Module service port
Module management port
CM88-CM:
● 1 x RJ45 console port
● 1 x RJ45 MGMT port
CM88-CM: 2 x USB 2.0 ports
RG-CS88-08
9.6 Tbps
7200 Mpps
CM88-CM: 8 GB
Line card: 8 GB
CM88-CM: 4 GB DDR4
Line card: 2 GB DDR4
● underlay: 30,000
● overlay: 0
● underlay: 50,000
Ingress
Egress
RG-CS88-08
10 RU
RG-CS88-08
4 x pluggable power modules
n+n power redundancy
RG-PA600I-F (AC input):
RG-PA1600I-F (AC input):
● Maximum input current: 16A
RG-PA600I-F: 600 W
RG-PA1600I-F:
Module power consumption
Line card:
● CM88-48GT-H: < 75 W
● CM88-48SFP-H: < 95 W
● CM88-48XS-H: < 160 W
● CM88-8CQ-H: < 130 W
RG-CS88-08
2 x pluggable fan modules
27°C (80.6°F): 70 dB
45°C (113°F): 77 dB
Module hot swapping
MGMT port : 4 kV
Service port: 4 kV
RG-CS88-08
RG-CS88 Series
MPLS IPv6
MPLS 6VPE
IPv4/IPv6 IS-IS
Policy-based routing (PBR)
EVPN
IGMP snooping v1/v2/v3
MLD v1/v2 snooping
802.1p
CAR
VRRP for the super-VLAN
Switch and Supervisor Module
RG-CS88-08
CM88-CM
Power Modules and Fans
RG-PA600I-F
RG-PA1600I-F
M08-FAN
CM88-48GT-H
CM88-48SFP-H
CM88-48XS-H
CM88-8CQ-H
