RG-S2915-10GT2MS-P-L Switches - 1
RG-S2915-10GT2MS-P-L Switches - 2
RG-S2915-10GT2MS-P-L Switches - 3
RG-S2915-10GT2MS-P-L Switches - 4
RG-S2915-10GT2MS-P-L Switches - 5
RG-S2915-10GT2MS-P-L Switches - 6
RG-S2915-10GT2MS-P-L Switches - 7
RG-S2915-10GT2MS-P-L Switches - 8
RG-S2915-10GT2MS-P-L Switches - 9
RG-S2915-10GT2MS-P-L Switches - 10
RG-S2915-10GT2MS-P-L Switches - 11
Killer Layer 2+ Access Switch
Applications
and Uninterrupted Connection
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
RG-S2915-24GT4MS-P-L
Fixed Service Ports
4 x 1GE/2.5GE SFP ports
24 x
2 x 1GE/2.5GE SFP ports
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
116 Gbps
68 Gbps
68 Gbps
30 Gbps
64 MB
512 MB DDR4
MAC Table Capacity
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
Shipping dimensions
(W x D x H) 1*
570 mm x 490 mm x 390 mm
580 mm x 450 mm x 380 mm
Shipping weight 1*
20.43 kg
(45.04 lbs)
18.18 kg
(40.08 lbs)
20.93 kg
(46.14 lbs)
15.98 kg
(35.23 lbs)
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
33 W (non-PoE)
403 W (full PoE load)
16 W (non-PoE)
141 W (full PoE load)
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
≤ 37 dB
≤ 39 dB
≤ 37 dB
Air discharge: 8 kV/15 kV
Contact discharge: 6 kV/8 kV
Power port: 6 kV/2 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
Telecom port: 10 kV
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
IEEE 802.1Q (4,094 VLANs)
Port based VLAN
SSHv1, SSHv2
IGMP V1,V2 snooping
Temperature Monitoring
Temperature Alarm
Overtemperature Protection
TFTP client
RG-S2915-48GT4MS-L
RG-S2915-24GT4MS-L
Optical Transceivers
