RG-S6250-48XS8CQ Switches - 1
RG-S6250-48XS8CQ Switches - 2
RG-S6250-48XS8CQ Switches - 3
RG-S6250-48XS8CQ Switches - 4
RG-S6250-48XS8CQ Switches - 5
RG-S6250-48XS8CQ Switches - 6
RG-S6250-48XS8CQ Switches - 7
RG-S6250-48XS8CQ Switches - 8
RG-S6250-48XS8CQ Switches - 9
RG-S6250-48XS8CQ Switches - 10
RG-S6250-48XS8CQ Switches - 11
RG-S6250-48XS8CQ 10GE Data Center Access Switch
  • 48 x 10GE SFP+ ports and 8 x 100GE QSFP28 ports
Data Center 10GE Access Switch RG-S6250-48XS8CQ
10GE high-density access switch with 10GE/100GE downlink ports and 100GE uplink ports backward compatible with 40GE for adaptation to different scenarios
Large buffer and advanced buffer scheduling mechanism, providing fast data processing and easily coping with burst traffic
De-stacking
M-LAG
RG-S6250-48XS8CQ
System
4.8 Tbps
2,000 Mpps
Port density
48 x 10GE SFP+ ports + 8 x 100GE QSFP28 ports
Expansion modules
Management port
1 x MGMT port, 1 x console port, and 1 x USB 2.0 port
4,094
(W x D x H)
8.2 kg (18.08 lbs., including two power modules and four fan modules)
Rated voltage: 110 V AC/220 V AC
Max. voltage range: 90 V AC to 264 V AC (47 Hz to 63 Hz)
Rated current range: 7.2 A to 3.5 A
HVDC input
Rated voltage: 240 V DC
Max. voltage range: 180 V DC to 310 V DC
Rated current: 3.6 A
LVDC input
Voltage range:
–36 V DC to –72 V DC
Rated voltage:
–48 V DC
Rated current:
23 A
Maximum Power Consumption
● Max: 300 W
● Typical: 165 W
● Static: 98 W
0ºC to 40ºC (32°F to 104°F)
–40°C to +70°C (–40°F to +158 °F)
Working altitude
RG-S6250-48XS8CQ
Layer 2 protocols
IEEE802.3ae (10GBASE), IEEE802.3ak, IEEE802.3an, IEEE802.3x, IEEE802.3ad (static link aggregation, LACP, MLAG), IEEE802.1p, IEEE802.1Q, IEEE802.1D (STP), STP Root Guard, BPDU Guard, IEEE802.1w (RSTP), IEEE802.1s (MSTP), IGMP Snooping , MLD Snooping, Jumbo Frame (9 Kbytes),
IEEE802.1ad (QinQ, selective QinQ), GVRP, access, trunk, and hybrid interfaces, LLDP, static MAC address, MAC address filter, MAC address limit
Layer 3 protocols (IPv4)
Static routing, BGP4, OSPFv2, IS-IS, RIPv1, RIPv2, MBGP, LPM Routing, Policy-based Routing (PBR), routing policy, ECMP, WCMP, VRRP, IGMP v1/v2/v3, PIM-SSM/SM/DM, MSDP, Any-RP, and BFD for BGP/IS-IS/OSPF/static routing, manual tunnel, GRE tunnel
Basic IPv6 protocols
Neighbor Discovery, ICMPv6, Path MTU Discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMPv6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTPv6, IPv6 MIB for SNMP, VRRPv6, and IPv6 QoS
IPv6 features
Static routing, ECMP, PBR, OSPFv3, RIPng, BGP4+, IS-ISv6, IPv6 VRRP, MLD v1/v2, PIM-SMv6, manually configured tunnel, GRE tunnel, automatic tunnel, IPv4 over IPv6 tunnel, and ISATAP tunnel
Data center features
EVPN Virtual eXtensible LAN (VXLAN)
VXLAN mapping
IPv4 VXLAN over IPv4
IPv6 VXLAN over IPv4
IPv4 VXLAN over IPv6
IPv6 VXLAN over IPv6
MLAG
OpenFlow 1.3
PFC, ECN
sFlow sampling
IPFIX sampling
802.1p, DSCP, and ToS mapping
Queue scheduling mechanisms such as SP (PQ), WRR, DRR, SP (PQ) + WRR, and SP (PQ) +DRR
Flexible queue scheduling algorithms based on ports or queues
Inbound/outbound rate limiting, CAR
MPLS VPN
Virtualization
Buffer management
Buffer usage monitoring and traffic microburst identification
High availability
GR for RIP/OSPF/BGP, BFD, DLDP, VRRP, VRRP load balancing/dual-active, BFD for VRRP, REUP, RLDP, 1+1 power redundancy and fan redundancy, and hot swappable line cards and power modules
Security features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), DDoS/DoS attack defense, ICMP attack defense, unauthorized packet detection, data encryption, source IP spoofing defense, IP scanning attack defense, RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL, port-based ACL, or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, uRPF, broadcast packet suppression, DHCP snooping, ARP spoofing defense (ARP anti-spoofing), ARP check, and hierarchical user management
Management mode
SNMP v1/v2c/v3, Telnet, Console, MGMT, RMON, SSHv1/v2, FTP/TFTP, NTP Syslog, SPAN/RSPAN/ERSPAN, Telemetry, ZTP, NETCONF, Python, fan and power alarm, temperature alarm, and configuration rollback
Other protocols
DHCP Client, DHCP Relay, DHCP Server, DNS Client, UDP Relay, Proxy ARP, and Syslog
RG-S6250-48XS8CQ
● NM EN 62368-1
● NM CEI 62368-1
● EN IEC 62368-1
● BS EN IEC 62368-1
● UL 62368-1
● CSA C22.2#62368-1
● EN IEC 61000-3-3
● EN 300 386
● ETSI EN 300 386
● NM EN 55035
● NM EN CEI61000-3-2
● NM EN 61000-3-3
● CNS 13438
● FCC CFR Title 47,
● Part 15, Subpart B
● ANSI C63.4-2014
● ICES-003 Issue 7
RG-S6250-48XS8CQ
RG-S6250-48XS8CQ chassis, 48 x 10GE SFP+ ports, 8 x 100GE QSFP28 ports, 2 x power module slots, 4 x fan module slots. The chassis is equipped with two power modules (RG-PA550I-F) and four fan modules (M1EFAN II-F).
Power Modules
RG-PA550I-F
550 W power module (supporting AC and 240 V HVDC)
RG-PD800I-F
800 W power module (supporting 48 V LVDC) for the RG-S6250-48XS8CQ and the RG-S6510-48VS8CQ
Fan Modules
M1EFAN II-F
Fan module (port-side intake) for the RG-S6250-48XS8CQ
M1EFAN III-F
Fan module (port-side intake) for the RG-S6231-48XT8CQ, the RG-S6231-48XS8CQ, the RG-S6232-48XS8CQ, and the RG-S6501-48VS8CQ
100G SR transceiver, QSFP28 form factor, MPO, 850 nm, 100 m (328.08 ft.) over MMF
10GBASE Series Optical Transceivers
10G SR transceiver, SFP+ form factor, Duplex LC, 300 m (984.25 ft.) over MMF
10G LR transceiver, SFP+ form factor, Duplex LC, 10 km (32,808.40 ft.) over SMF
10G ER transceiver, SFP+ form factor, Duplex LC, 40 km (131,233.60 ft.) over SMF
10G ZR transceiver, SFP+ form factor, Duplex LC, 80 km (262,467.19 ft.) over SMF
XG-LR-SM1310
10G AOC cable, SFP+ form factor, 1 m (3.28 ft.)
10G AOC cable, SFP+ form factor, 3 m (9.84 ft.)
10G AOC cable, SFP+ form factor, 5 m (16.40 ft.)
XG-SR-MM850
1000BASE Series Optical Transceivers
1G LH transceiver, SFP form factor, BIDI LC, 40 km (131,233.60 ft.) over SMF
1G LX transceiver, SFP form factor, BIDI LC, 20 km (65,616.80 ft.) over SMF
1G LH transceiver, SFP form factor, Duplex LC, 40 km (131,233.60 ft.) over SMF
1G LX transceiver, SFP form factor, Duplex LC, 10 km (32,808.40 ft.) over SMF
1G SR transceiver, SFP form factor, Duplex LC, 550 m (1,804.46 ft.) over MMF
1G ZX transceiver, SFP form factor, Duplex LC, 80 km (262,467.19 ft.) over SMF
1000BASE Series Electrical Transceivers
Mini-GBIC-GT(F)
1G electrical transceiver, SFP form factor, RJ45, 100 m (328.08 ft.) over Cat 5e/6/6a. For the S6200 series, the Mini-GBIC-GT(F) module applies to only the RG-S6250-48XS8CQ.
