The RG-S2915-10GT2MS-P-L and RG-S2915-24GT4MS-P-L are recommended. They provide up to 30 W power per port to meet power supply needs of terminals such as VoIP phones, IP cameras, and access points (APs).
Yes. The RG-S2915-24GT4MS-L switch adopts a fanless design and dissipates heat in a natural manner without noise. Even if your office is near the equipment room, you are free of worries about noises. The switch also supports energy efficient Ethernet (EEE). Idle ports shut down automatically to save power.
Yes. The 2.5G fiber ports of the switch are compatible with SFP transceiver modules and backward-compatible with 1000 Mbps.
RG-S2915-48GT4MS-L |
RG-S2915-24GT4MS-L |
RG-S2915-24GT4MS-P-L |
RG-S2915-10GT2MS-P-L |
Fixed Service Ports |
Power modules |
1 fixed power module |
Fans modules |
2 fixed fans |
0 |
2 fixed fans |
1 fixed fans |
Fixed management ports |
Packet forwarding rate |
87 Mpps |
51 Mpps |
51 Mpps |
22.5 Mpps |
System Switching capacity |
116Gbps |
68Gbps |
68Gbps |
30Gbps |
MAC Table Capacity |
16,000 |
16,000 |
16,000 |
16,000 |
ARP table |
512 |
64 |
ACL entries |
500 |
2.8 kg (6.17 lbs) |
2.5 kg (5.51 lbs) |
2.8 kg (6.17 lbs) |
2.5 kg (5.51 lbs) |
Storage |
Power and Consumption |
< 30 W |
< 15.6 W |
Rated input voltage |
>200K |
>200K |
>200K |
>200K |
Operating Temperature |
0°C to 45°C (32°F to 113°F) |
Storage Temperature |
Operating Humidity |
Storage Humidity |
Operating noise |
≤ 37 dB |
Fanless |
≤ 39 dB |
≤ 37 dB |
Interface surge protection |
Feature |
Ethernet switching |
802.3az EEE |
IEEE 802.1Q (4,094 VLANs) |
Port based VLAN |
Basic QinQ Selective QinQ |
LACP (IEEE 802.3ad) |
IP service |
ARP |
DHCP snooping |
IP routing |
RIP, RIPng |
OSPFv2 |
Port traffic rate limiting |
RADIUS and TACAS+ |
HTTPS |
SSHv1, SSHv2 |
IGMP V1,V2 snooping |
IP Source Guard |
RLDP |
RSPAN |
sFlow |
NTP |
TFTP client |
SNMP v1/v2c/v3 |
2.5G-SFP-LX03-SM1310-BIDI-I |
2.5G-SFP-LX03-SM1550-BIDI-I |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
