RG-S6980-128DC Switches - 1
RG-S6980-128DC Switches - 2
RG-S6980-128DC Switches - 3
RG-S6980-128DC Switches - 4
RG-S6980-128DC Switches - 5
RG-S6980-128DC Switches - 6
RG-S6980-128DC – 128-Port 200GE Data Center Fixed Core Switch
High-density 200GE fixed switch, support for 200GE optical transceivers
  • High-density 200GE switch with 128 x 200GE QSFP56 ports housed in a 4-RU enclosure
  • Hardware-level redundancy, ensuring service continuity and preventing network downtime
  • Telemetry-based network monitoring and automated O&M, making management easy and efficient
RG-S6980-128DC – 128-Port 200GE Data Center Core Switch
The high-speed and high-density core switch provides 128 x 200GE QSFP56 ports housed in a 4-RU enclosure,
delivering scalable, high-performance, and high-bandwidth services for large-scale DCI networks.
Hardware-Level Redundancy, Ensuring Service Continuity and Preventing Network Downtime
The switch supports 2+2 power redundancy, enables failover in seconds, and ensures network connectivity during power replacement. This provides dual protection for links.
Lossless Ethernet, Ensuring Zero Packet Loss During RDMA E2E Communication
With the RDMA technology, data does not need to be handled by the CPU during device communication. This reduces the CPU load
and addresses network latency issues.
PFC and ECN are leveraged to implement intelligent data exchange and eliminate packet loss, ensuring lossless transmission of data.
Telemetry-based Network Monitoring and Automated O&M, Making Management Easy and Efficient
The switch enabled with telemetry provides a comprehensive view of data status and hierarchy.
The switch proactively collects and pushes information to provide sub-second-level network monitoring in real time,
System
RG-S6980-128DC
128 x 200GE ports (QSFP56)
Power Modules
Four power module slots, supporting 2+2 redundancy
Fan Modules
Eight fan module slots, supporting 7+1 redundancy
Management Ports
51.2 Tbps
10,300 Mpps
(W x D x H)
442 mm x 760 mm x 175 mm (17.40 in. x 29.92 in. x 6.89 in., 4 RU)
Net Weight
39.65 kg (87.41 lbs., including eight fan modules and four power modules)
Maximum Power Consumption
2,550 W
AC
Rated voltage range: 100 V AC to 127 V AC
Frequency: 50 Hz to 60 Hz
Maximum rated input current: 12 A
Rated voltage range: 200 V AC to 240 V AC
Maximum rated input current: 8 A
High-Voltage DC
Voltage: 240 V DC
Maximum rated input current: 6.5 A
0°C to 40°C (32°F to 104°F)
0 m to 1,800 m (0 ft. to 5,905.51 ft.)
RG-S6980-128DC
BGP4, OSPFv2, RIPv1, RIPv2, LPM routing, PBR, routing policy, ECMP, WCMP, VRRP
Neighbor discovery, ICMPv6, path MTU discovery, DNSv6, DHCPv6, ICMPv6, ICMPv6 redirection, ACLv6, TCP/UDP for IPv6, SNMPv6, Ping/Traceroute v6, IPv6 RADIUS, Telnet/SSH v6, FTP/TFTP v6, NTP v6, IPv6 MIB support for SNMP, VRRP for IPv6, IPv6 QoS, static routing, ECMP routing, PBR, OSPFv3, RIPng, BGP4+
Data Center Features
PFC, ECN
RDMA
VXLAN, BGP-EVPN
PFC deadlock prevention
* AI ECN
* ECN overlay
RALB, AILB
Collecting data including basic switch information, real-time RoCE buffer state, interface-based QoS queue and real-time interface utilization, ECN and PFC events, and media side SNR* through telemetry
802.1p, DSCP, and ToS mapping
Multiple queue scheduling mechanisms, including SP, WRR, WFQ, DRR, SP+WRR, SP+WFQ, and SP+DRR
Hgh Availability Design
GR for RIP/OSPF/BGP, BFD, REUP, Rapid Link Detection Protocol (RLDP), 2+2 power redundancy, fan redundancy, and hot swappable line cards and power modules
Security Features
Network Foundation Protection Policy (NFPP), CPU Protection Policy (CPP), RADIUS/TACACS, IPv4/v6 packet filtering by basic ACL, extended ACL or VLAN-based ACL, cleartext and MD5-based authentication for OSPF, RIPv2, and BGPv4 packets, Telnet login from specified IP addresses, broadcast packet suppression, and hierarchical user management
Management Mode
SNMP v1/v2/v3, Telnet, console, MGMT, RMON, SSH v1/v2, FTP/TFTP, NTP, syslog, SPAN/RSPAN/ERSPAN, ZTP, NETCONF, Python, fan and power alarm, and overheat alarm
DHCP client, DHCP relay, DHCP server, DNS client, proxy ARP, and syslog
RG-S6980-128DC
128 x 200GE ports, four power module slots, eight fan module slots
PSA1300CRPS-F-RJ
FAN12K8080-F-RJ
100GBASE Optical Transceivers
100G SR transceiver, QSFP28 form factor, MPO, 850 nm, 100 m (328.08 ft.) over MMF
100G-AOC-1M
100G AOC cable, QSFP28 form factor, 1 m (3.28 ft.)
200GBASE Optical Tranceivers
200G-Q56-SR4-MM850(D)
200G SR4 transceiver, QSFP56 form factor, MPO-12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MMF, in compliance with CMIS, applied to the switch side.
200G-Q56-SR4-MM850
200G SR4 transceiver, QSFP56 form factor, MPO-12/APC, 850 nm, 100 m (328.08 ft.) over OM4 MMF, in compliance with SFF-8636, applied to the server side.
