10G/5G/2.5G/1G/100M access, PoE/PoE+/PoE++, 4 x 10G and 2 x 25G uplink optical ports, offering flexible networking options to build high-performance campus networks
24 x 10G electrical ports, 4 x 10G optical ports, 4 x 25G optical ports
RG-S6120-48XMG4VS2QXS-UP-H48 x 10G electrical ports, 4 x 25G optical ports, 2 x 40G optical ports
RG-S6110-24MG4VS-UP24 x 5G electrical ports, 4 x 25G optical ports
RG-S6110-48MG4VS2QXS-UP48 x 5G electrical ports, 4 x 25G optical ports, 2 x 40G optical ports
RG-S6110-24MG4VS-UP |
RG-S6110-48MG4VS2QXS-UP |
RG-S6120-24XMG4XS4VS-UP-H |
RG-S6120-48XMG4VS2QXS-UP-H |
Fixed port |
24 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation 4 x 10GE/25GE SFP28 ports Ports 1 to 24 support PoE/PoE+ and HPoE power supply (maximum output power of a HPoE-capable port: 90 W) |
48 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation 4 x 10GE/25GE SFP28 + 2 x 40GE QSFP+ ports Ports 1 to 48 support PoE/PoE+ power supply (ports 1 to 24 support HPoE power supply, maximum output power of a HPoE-capable port: 90 W) |
24 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation 4 x 10GE SFP+ ports 4 x 25GE SFP28 ports Ports 1 to 24 support PoE/PoE+ and HPoE power supply (maximum output power of a HPoE-capable port: 90 W) |
48 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation 4 x 10GE/25GE SFP28 + 2 x 40GE QSFP+ ports Ports 1 to 48 support PoE/PoE+ power supply (ports 1 to 24 support HPoE power supply, maximum output power of a HPoE-capable port: 90 W) |
Fan module |
2 x fixed fan modules Fan speed regulating and fault alarms |
3 x fan module slots Fan speed regulating and fault alarms |
Power module |
1 x built-in power module |
2 x power module slots |
Fixed management port |
1 x MGMT port, 1 x console port, and 1 x USB2.0 port |
System packet forwarding rate * |
392 Mpps |
750 Mpps |
678 Mpps |
982 Mpps |
System switching capacity * |
528 Gbps |
1008 Gbps |
912 Gbps |
1320 Gbps |
Number of MAC addresses |
16,000 |
16,000 |
16,000 |
16,000 |
ND table size |
4,000 |
4,000 |
4,000 |
4,000 |
16,000 |
16,000 |
16,000 |
16,000 |
4,000 |
4,000 |
4,000 |
4,000 |
16,000 |
16,000 |
16,000 |
16,000 |
2,000 |
2,000 |
2,000 |
2,000 |
Number of IGMP groups |
4,000 |
Number of MLD groups |
1,000 |
Ingress: 2,500 Egress: 1,000 |
Number of VSU members |
2 |
2 |
2 |
2 |
442 mm x 220 mm x 43.6 mm (17.40 in. x 8.66 in. x 1.72 in.) |
442 mm x 420 mm x 43.6 mm (17.40 in. x 16.54 in. x 1.72 in.) |
Weight (chassis and fan modules) |
3.65 kg (8.05 lbs) |
6.11 kg (13.47 lbs) |
1.2 GHz single-core processor |
Storage |
1 GB DDR4 1 GB flash memory |
2 GB DDR4 1 GB flash memory |
Data packet buffer |
4 MB |
4 MB |
4 MB |
4 MB |
Power and Consumption |
Without PoE: < 120 W Full PoE load: < 370 W |
Without PoE: < 240 W Full PoE load: < 1,600 W |
Without PoE: < 120 W Full PoE load: < 1,650 W |
Maximum output power |
Built-in power: 460 W (370 W for PoE output power supply and 90 W for the chassis) |
RG-PA600I-P-F: 600 W (400 W/450 W for PoE output power supply and 150 W/200 W for the chassis) RG-PA1000I-P-F: 1,000 W (800 W/850 W for PoE output power supply and 150 W/200 W for the chassis) |
Rated input voltage |
AC input: 100 V AC to 240 V AC Frequency: 50/60 Hz Rated current per circuit: 6 A |
RG-PA600I-P-F: ● AC input: 100 V AC to 240 V AC ● Frequency: 50/60 Hz ● Rated current per circuit: 8 A RG-PA1000I-P-F: ● AC input: 100 V AC to 240 V AC ● Frequency: 50/60 Hz ● Rated current per circuit: 8 A |
90 V AC to 264 V AC |
22.18 years |
27.02 years |
22.18 years |
27.02 years |
Primary airflow |
Front/Left-to-rear airflow |
0°C to 45°C (32°F to 113°F) |
Operating altitude |
–500 m to +3000 m (–1640.42 ft. to +9842.52 ft.) |
Operating noise |
Typical value: < 40 dBA@27°C (80.6°F) Maximum value < 78 dBA |
Typical value: < 60 dBA@27°C (80.6°F) Maximum value < 78 dBA |
Interface surge protection |
6 kV |
Software Specifications |
RG-S6100 Series |
Ethernet switching |
Super-VLAN and private VLAN |
LACP (IEEE 802.3ad) |
IP service |
Static and dynamic ARP |
IP routing |
OSPFv2 and OSPFv3 |
GR |
IS-ISv4 and IS-ISv6 |
BGP4 and BGP4+ |
Stateless Auto Configuration |
IPv4/IPv6 VRF |
IPv4/IPv6 PBR |
IGMPv1/v2/v3 and IGMP proxy |
IGMPv1/v2/v3 snooping |
PIM-DM, PIM-SM, and PIM-SSM |
PIM-SSM for IPv4 and IPv6 |
MLDv1/v2 |
MLD snooping |
MSDP |
PIM-SMv6 |
Multicast querier |
Time-based ACLs |
ACL80 and IPv6 ACL |
Port traffic identification |
Port traffic rate limiting |
Traffic classification based on ToS values |
Eight queues on each port |
Rate limiting in each queue |
Multi-AAA |
RADIUS and TACAS+ |
Filtering of invalid MAC addresses Broadcast storm suppression Hierarchical management of administrators and password protection BPDU guard |
SSHv1 and SSHv2 |
Global IP-MAC binding |
ICMPv6 |
Port security |
SAVI |
ARP spoofing prevention |
REUP |
BFD |
GR for RIP, OSPF, and BGP |
Power modules in 1+1 redundancy mode |
Hot swapping of power modules and fan modules (not supported by the RG-S6110-24MG4VS-UP) |
VSU |
SPAN, RSPAN, and ERSPAN |
sFlow |
NTP and SNTP |
FTP and TFTP |
SNMP v1/v2/c3 |
RMON (1, 2, 3, 9) |
NETCONF |
CWMP |
Follow the steps to order an RG-S6100 multi-GE switch:
Models marked with asterisks (*) in Ordering Information will be available in the future.
24 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation 4 x 10GE/25GE SFP28 ports |
48 x 100M/1000M/2.5GE/5GE electrical ports with auto-negotiation 4 x 10GE/25GE SFP28 + 2 x 40GE QSFP+ ports |
24 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation 4 x 10GE SFP+ ports 4 x 25GE SFP28 ports |
48 x 100M/1000M/2.5GE/5GE/10GE electrical ports with auto-negotiation 4 x 10GE/25GE SFP28 + 2 x 40GE QSFP+ ports |
RG-PA600I-P-F |
600 W AC power module |
RG-PA1000I-P-F |
1000 W AC power module |
RG-PA150I-F |
150 W AC power module |
GE-SFP-LX20-SM1310-BIDI |
GE-SFP-LX20-SM1550-BIDI |
GE-SFP-LH40-SM1310-BIDI |
GE-SFP-LH40-SM1550-BIDI |
10GE LC connector module, applicable to the SFP+ port 62.5 μm/125 μm: 33 m 50 μm/125 μm: 66 m Modal bandwidth of 2000 MHz·km for a link length of up to 300 meters |
10GE LC connector module with a link length of up to 40 km, 1310-nm wavelength, applicable to the SFP+ port |
10GE LC connector module with a link length of up to 40 km, 1550-nm wavelength, applicable to the SFP+ port |
10GE SFP+ port cable, 1 m, including one cable and two interface modules |
10GE SFP+ port cable, 3 m, including one cable and two interface modules |
10GE SFP+ port cable, 5 m, including one cable and two interface modules |
VG-SFP-SR-MM850 |
VG-SFP-LR-SM1310 |
VG-SFP-AOC5M |
40G-QSFP-SR-MM850 |
40GE SR, QSFP+ transceiver, applicable to QSFP+ ports OM3 and OM4 MMF, MPO, 8-core, 850-nm wavelength, 100 m over OM3 MMF or 150 m over OM4 MMF |
40G-QSFP-LR4 SM1310 |
40G-AOC-5M |
40G-AOC-10M |
