Applicable in VSU networking scenarios, provides two uplink splitting ports, and works together with RG-MUX-8LC/LC-H.
8-port modular transparent distribution device used with splitters
Product Specifications |
RG-MUX-8LC/LC |
RG-MUX-8LC/LC-H |
RG-MUX-EXT |
Fixed service port |
8 x demultiplexing ports, supporting 1GE/2.5GE/10GE 1 x multiplexing port |
8 x demultiplexing ports, supporting 1GE/2.5GE/10GE 1 x multiplexing port, supporting connection to a dual-uplink splitter |
1 x multiplexing port 2 x uplink ports for optical splitting |
Wavelength range |
1271 nm to 1571 nm (CWDM) |
Channel spacing |
20 nm |
20 nm |
20 nm |
Channel bandwidth |
±6 nm |
±6 nm |
±6 nm |
Insertion loss |
< 3.7 dB |
< 2.6 dB |
< 4.2 dB |
Return loss |
> 45 dB |
> 45 dB |
> 45 dB |
Polarization loss |
< 0.3 dB |
< 0.3 dB |
< 0.3 dB |
Adjacent channel isolation |
> 25 dB |
> 25 dB |
> 35 dB |
> 35 dB |
Connector type |
LC/UPC |
LC/UPC |
LC/UPC |
Unit dimensions (W x D x H) |
149.0 mm x 140.5 mm x 22.0 mm (5.87 in. x 5.53 in. x 0.87 in.) |
405 mm x 378 mm x 425 mm (15.94 in. x 14.88 in. x 16.73 in.) |
Unit weight |
0.25 kg (0.55 lbs) |
0.15 kg (0.33 lbs) |
Shipping weight |
4.53 kg (9.99 lbs) |
Mounting |
Mounting on a wall or in a rack (cabinet) |
Temperature |
Operating temperature: 0°C to 55°C (32°F to 131°F) Storage temperature: –40°C to +85°C (–40°F to +185°F) |
Humidity |
Operating humidity: 5% to 95% RH (non-condensing) Storage humidity: 5% to 95% RH (non-condensing) |
Altitude |
Same as the specification of the SOE switch |
Communication standard |
RG-MUX-BOX |
Module slot |
6 x transparent distribution device/dual-uplink splitter slots |
442 mm x 50 mm x 58 mm (17.4 in. x 1.97 in. x 2.28 in.) |
557 mm x 358 mm x 271 mm (21.93 in. x 14.09 in. x 10.67 in.) |
Unit weight |
0.9 kg (1.98 lbs) |
Shipping weight |
11.5 kg (25.35 lbs) |
Mounting |
Temperature |
Operating temperature: –40°C to +85°C (–40°F to +185°F) Storage temperature: –40°C to +85°C (–40°F to +185°F) |
Humidity |
Altitude |
RG-MUX-8LC/LC |
Building-side 8-port transparent distribution device, 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port |
RG-MUX-8LC/LC-H |
Building-side 8-port transparent distribution device (high-end version with low insertion loss), 8 x 1GE/2.5GE/10GE demultiplexing ports, 1 x multiplexing port, supporting connection to a dual-uplink splitter |
RG-MUX-EXT |
Building-side transparent distribution device's expansion module, or optical dual-uplink splitter (delivered with short fiber jumpers), which connects to the transparent distribution device and provides 1-to-2 optical signal splitting to realize dual-uplink networking; 1 x multiplexing port, 2 x uplink ports for optical splitting |
RG-MUX-BOX |
Building-side transparent distribution device subrack, 6 x transparent distribution device/dual-uplink splitter slots |
SFG-LR-SM |
Core switch side, 1G BASE-LR,SFG Transceiver, 8 different wavelengths (10 km, LC) |
SFX-LR-SM |
Core switch side, 10G BASE-LR, SFP+ Transceiver, 8 different wavelengths (10 km, LC) |
GE-SFP-LR(A1-4)-H |
Access switch side, 1G BASE-LR, SFG Transceiver, 4 different wavelengths (10 km, LC), used in dual uplink scenarios |
GE-SFP-LR(A1-8)-H |
Access switch side, 1G BASE-LR, SFG Transceiver, 8 different wavelengths (10 km, LC), used in dual uplink scenarios |
XG-SFP-LR(A1-4)-H |
Access switch side, 10G BASE-LR, SFP+ Transceiver, 4 different wavelengths (10 km, LC), used in dual uplink scenarios |
XG-SFP-LR(A1-8)-H |
Access switch side, 10G BASE-LR, SFP+ Transceiver, 8 different wavelengths (10 km, LC), used in dual uplink scenarios |
