RG-CS83-24GT4XS,24-Port GE Electrical Layer 3 Managed Access Switch
RG-CS83-24GT4XS
Gigabit access switch for large-sized enterprise and campus LANs, with four 10G uplink optical ports for high-speed data transmission 24 x 1000 Mbps Ethernet ports,providing high-speed network access for short-distance services and flexible networking
Flexible installation
Silence
Carrier-class Reliability
Make Your Business Easy
Flexible Management Modes
Documentos
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
12 x 100M/1000M  BASE-T ports
support PoE+
24 x 100M/1000M BASE-T ports
48 x 100M/1000M BASE-T ports
support PoE+
support PoE+
78 Mpps
104 Gbps
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3 kg (6.61 lbs)
3.75 kg (8.27 lbs)
1.0 GHz dual-core CPU
< 35 W (non-PoE)
< 405 W (PoE full load)
< 40 W
< 35 W (non-PoE)
< 52 W (non-PoE)
< 460 W (PoE full load)
409 W
Maximum  PoE output :370W
409 W
460 W
Maximum  PoE output :405W
100 V AC to 240 V AC
24.14 years
23.74 years
23.85 years
23.94 years
22.86 years
27℃: < 35 dB
< 20 dB
27℃: < 32 dB
27℃: < 35 dB
27℃: < 35 dB
Communication port: 10 kV
RG-CS83 Series
SPAN, RSPAN
Interface priority
RG-CS83-12GT4XS-P
RG-CS83-24GT4XS
RG-CS83-48GT4XS
RG-CS83-24GT4XS-P
RG-CS83-48GT4XS-P
